It is currently Thu May 21, 2026 9:19 am
Which term do you use for the "Study"
Arc Flash Study 78%  78%  [ 7 ]
Incident Energy Analysis 22%  22%  [ 2 ]
Risk Assessment 0%  0%  [ 0 ]
Arc Flash Calculation Study 0%  0%  [ 0 ]
Arc Flash Hazard Analysis 0%  0%  [ 0 ]
Something else – please list 0%  0%  [ 0 ]
Total votes : 9
 Post subject: What term do you use for the “Study”?
PostPosted: Sun May 03, 2026 6:49 am
I was at a committee meeting recently and we began over thinking what you call a study that includes the calculation of incident energy, arc flash boundary, arcing current, labeling, and report. It may include shock boundaries, and short circuit and coordination analysis.
There are many different terms used but none of us recall a standardized term for this study.
Some of the common terms are:
Arc Flash Study
Risk Assessment
Which term do you use most often?
 Post subject: Re: What term do you use for the “Study”?
PostPosted: Mon May 04, 2026 3:08 pm
Generally I refer to it as an Arc Flash Study. I consider the other options to be subsets of a general study. These subsets may be performed or ignored depending on the customers need and scope of work. A complete Arc flash Study encompasses all of these options.
PostPosted: Tue May 05, 2026 11:18 am
I selected the first, but I use more than one depending on the context. I often prefer arc fault study, since an arc might not always "flash", but I'm aware the difference is somewhat arbitrary.
