It is currently Fri Aug 19, 2022 11:26 pm
ekstra   ara
 Post subject: Anyone else notice 130.6 is missing?
PostPosted: Wed Sep 22, 2021 11:42 am
I was updating my presentation's references from 2018 70E to 2021 70E and noticed that 130.6 Other Precautions for Personal Activities is missing from the 2021 70E edition.
I checked the 2021 70E handbook addition and it only has a Exhibit 130.6. The text for 130.6 is not there nor any elaboration.
Was this a deliberate omission and if so why does it keep the article numbering system and just jump from 130.5 to 130.7?
 Post subject: Re: Anyone else notice 130.6 is missing?
PostPosted: Wed Sep 22, 2021 2:02 pm
Relocated to 130.8.
Mike
PostPosted: Thu Sep 23, 2021 9:19 am
Thanks.
I did find that after researching my question a bit more.
130.12 was added to that article also.
I'm just curious/confused about why they just skipped 130.6 and was it done that way for some reason.
Is there a future revision that will bring back 130.6 or will they renumber the entire article in the next addition.
P Sears
PostPosted: Thu Sep 23, 2021 11:22 am
That is pretty common. When a section is moved, we often keep it as "not used" so all the sections that follow don't need to be renumbered.
Another example was in the Informative Annexes. Annex B was combined with Annex A in 2018 so Annex B was listed as "Reserved". That way Annex C through Q didn't need to be re-indexed.
© 2022 Arcflash Forum / Brainfiller, Inc. | P.O. Box 12024 | Scottsdale, AZ 85267 USA | 800-874-8883
