Arc Flash Forum
Soft Starters
https://brainfiller.com/arcflashforum/viewtopic.php?f=4&t=1299
Page 1 of 1
Author:  bruinfan [ Tue Sep 21, 2010 1:00 pm ]
Post subject:  Soft Starters
How do reduced voltage soft starters effect short circuit currents? How are these even modeled in SKM (software I am using)?
Thanks in advance!
Author:  mountaineer [ Tue Sep 28, 2010 6:03 am ]
I don't use SKM but I was advised to model the soft starts as across the line starters. The reason is that once the motor comes up to speed, typically a contactor closes bypasses the "soft start." It then operates as a typical starter.
http://www.phpbb.com/
