Arc Flash Forum
Causual effect on separate branch following an arc flash incident
https://brainfiller.com/arcflashforum/viewtopic.php?f=4&t=318
Page 1 of 1
Author:  kurtekrueger [ Fri Jan 30, 2009 1:25 pm ]
Post subject:  Causual effect on separate branch following an arc flash incident
Is it likely for an arc flash incident on one branch from primary distribution panel which tripped breaker to blow a fuse in a control panel of a separate branch?
Author:  SirSpark [ Fri Jan 30, 2009 2:18 pm ]
The transient that occurred during the incident could feasibly effect anything downstream of the incident, so yes it could.
As in the rapid fluctuations in voltage could cause a fuse with in a control device to draw enough amperage to melt its element.
http://www.phpbb.com/
