| Arc Voltage accross 1mm Gap https://brainfiller.com/arcflashforum/viewtopic.php?f=4&t=502 |
Page 1 of 1 |
| Author: | djho [ Fri Jun 19, 2009 10:28 am ] |
| Post subject: | Arc Voltage accross 1mm Gap |
Bonjour, I'm working on a DC arc generator. This generator is able to create an arc beetween two electrodes of tungsten. The DC Voltage is about 300V and the arc is stable. I measure the arc voltage of about 200V for a gap of 1mm. I have found figures with the arc voltage and current for different gaps here : http://www.arcadvisor.com/faq/dc_direct_current_arc.html. This figures tells that the voltage must be of about 50V for 10 mm gap, and this is in condradiction with my measure. My question : is my measure false (have i ommitted something) or are the figures false ? Thanks |
| Author: | djho [ Mon Jun 22, 2009 2:03 am ] |
| Post subject: | |
Nobody knows ? |
| Author: | arcad [ Tue Sep 15, 2009 3:59 am ] |
| Post subject: | |
Please provide the generator load curve. - Michael www.arcadvisor.com |
| Author: | djho [ Thu Nov 19, 2009 5:41 am ] |
| Post subject: | |
The generator is a simple transformer whith a rectifier device to generate DC voltage. I haven't got yet the generator load but what i'm sure is that it's neglgible to the resistive serial load I added for arc current control. How can this generator load change the Arc voltage ? |
