It is currently Fri Jun 19, 2026 8:46 pm
 Post subject: Capacitive test points - phasing
PostPosted: Thu Apr 24, 2025 6:28 am
We are looking to hot phase between two 15kV cables. These cables have Tyco elbows installed on the ends of them which include a capacitive voltage test point. When using these test points, what kind of safety precautions need to be made?
 Post subject: Re: Capacitive test points - phasing
PostPosted: Fri Apr 25, 2025 7:58 am
Use a hot stick / shotgun to take them off. Then you can use your proximity tester (attached to a hot stick / shotgun) to test for 0 volts.
Mike
