Congratulations and thanks for taking part in this very important process!!
You should be notified so you have the opportunity to provide public comment.
Also, you can view the
first draft report (link below) to see the proposals and see the balloting results. If you have not created a profile, you will need to do that first.
https://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards/detail?code=70E&tab=nextedition
