Arc Flash Forum
Wound Rotor Circuit Arc Flash Risk
https://brainfiller.com/arcflashforum/viewtopic.php?f=8&t=5346
Page 1 of 1
Author:  RECS [ Thu Aug 13, 2020 11:35 am ]
Post subject:  Wound Rotor Circuit Arc Flash Risk
An engineer asked my the following question.
Wound rotor induction motors have an external circuit coming from the motor rotor, through slip rings, to a variable resistor bank. The slip ring enclosure and the resistor bank cabinet have an arc flash risk. Is there an established method/standard for calculating the incident energy along the motor secondary circuit? Have you ever run into the situation before?
I do not have any experience with wound rotor induction motors.
Any one cares to enlighten me? Thanks.
http://www.phpbb.com/
