I want to model a Dynamometer in SKM and there are many unknowns in this project for the moment. My strategy is to divide and conquer.
Currently the dynamometer will be fed by an upstream feeder circuit breaker (FCB-02) which is attached to a VFD. FCB-02 is fed by an isolation transformer which is fed by an upstream breaker (FCB-01).
Questions:
In the Dynamometer Manufacturer Sheet it states 450Hp ABS & Rated 400Hp. What is ABS stand for?
I will post most questions once this thread developes.
Thank you all.
