It is currently Wed Oct 14, 2026 1:21 am
 Post subject: App for figuring safe approach distances?
PostPosted: Thu Mar 21, 2013 4:20 pm
Does anyone know of an app that has been created that will figure the safe approach distances using the new tables in NFPA 70E 2012?
Thank you for your responses.
Priscilla Anderson :D
PostPosted: Fri Mar 22, 2013 12:16 pm
Not sure what the app would buy you? Why not just use the Notes feature and type the limits from table into a Note?
PostPosted: Mon Mar 25, 2013 5:43 am
I agree with "wbd" if you need a chart the helps you figure out the PPE level for each HRC go to [url="http://www.FacilityResults.com"]www.FacilityResults.com[/url] and check out the downloads tab. Lots of great tools.
Bryan Rupert
[url='http://facilityresults.com/W1/']Facility Results[/url]
PostPosted: Tue Mar 26, 2013 9:54 am
OK, really good input. One of our Risk Coordinators suggested that I ask for one, I think he envisioned a program that had the tables already incorporated into it, and where you just punch in your specific voltages, etc. and then it figures it. But I see your point, it is almost as easy to use those tools.
I'll check them out, thank you so much!
