| Author |
Message |
sam314159
Post subject: Replacing AF Labels Posted: Thu Sep 22, 2016 8:32 am |
I will be updating arc flash labels on numerous working locations which means the old label has to be removed and a new one applied. By design these labels are very rugged and difficult to peel off. Anyone have experience with tools or techniques that make the old label removal more time efficient?
I'm not a huge fan of sticking new labels on old labels unless it's unavoidable, I think it looks sloppy unless the two labels were perfectly lined up.
| Top |
Voltrael
Post subject: Re: Replacing AF Labels Posted: Thu Sep 22, 2016 8:48 am |
| Sparks Level |
Joined: Tue Nov 12, 2013 6:31 am Posts: 238 Location: Port Huron, Michigan
I never remove labels; they are too hard to remove. I just line it up as best I can and cover the old one with a new one.
| Top |
bbaumer
Post subject: Re: Replacing AF Labels Posted: Thu Sep 22, 2016 12:32 pm |
| Arc Level |
Joined: Fri Jul 08, 2016 10:01 am Posts: 440 Location: Indiana
Voltrael wrote: I never remove labels; they are too hard to remove. I just line it up as best I can and cover the old one with a new one. +1
_________________ SKM jockey for hire PE in 17 states
| Top |
JBD
Post subject: Re: Replacing AF Labels Posted: Fri Sep 23, 2016 12:06 pm |
Joined: Mon Jan 18, 2010 11:35 am Posts: 604 Location: Wisconsin
Voltrael wrote: I never remove labels; they are too hard to remove. I just line it up as best I can and cover the old one with a new one. What I hate is when the old one is crooked. I have gotten away from insisting the AF label must be of the most permanent construction available. I seem to regularly find cheap paper shipping instructions labels still on 40 yr old gear.
| Top |
PaulEngr
Post subject: Re: Replacing AF Labels Posted: Sat Sep 24, 2016 8:29 am |
| Plasma Level |
Joined: Tue Oct 26, 2010 9:08 am Posts: 2178 Location: North Carolina
Heat gun. But be careful. Too much and you strip the paint. Just enough to soften the glue and peel it up. Once removed you can either stick the old label back down or use a little solvent to clean up the residue first. Again too much or use a really aggressive solvent like brake cleaner and you take out the paint, too.
| Top |
arcad
Post subject: Re: Replacing AF Labels Posted: Mon Sep 26, 2016 6:40 am |
| Sparks Level |
Joined: Wed Jun 10, 2009 5:00 pm Posts: 271 Location: Toronto
Begin by heating one corner of the marking with a blow dryer, heat lamp, hot water or heat gun until hot to the touch. Pick up and lift that area you just heated (use a razor only on glass surfaces). Slowly begin pulling back the decal, at less than a 90 degree angle. Continue applying heat to the area just before the area that is being removed. Once you have removed the marking, check to make sure that all of the adhesive residue has been removed. Remaining residue may be removed by using Isopropyl alcohol (rubbing alcohol). (source: http://arcadvisor.com/faq/apply-vinyl-label-decals)
| Top |
bbaumer
Post subject: Re: Replacing AF Labels Posted: Mon Sep 26, 2016 8:06 am |
| Arc Level |
arcad wrote: Begin by heating one corner of the marking with a blow dryer, heat lamp, hot water or heat gun until hot to the touch. Pick up and lift that area you just heated (use a razor only on glass surfaces). Slowly begin pulling back the decal, at less than a 90 degree angle. Continue applying heat to the area just before the area that is being removed. Once you have removed the marking, check to make sure that all of the adhesive residue has been removed. Remaining residue may be removed by using Isopropyl alcohol (rubbing alcohol). (source: http://arcadvisor.com/faq/apply-vinyl-label-decals) If I did all that I'd never get done with the job. It would take longer to the the bleeping labels on than to do the study. Certainly not worth the effort. Just put the new label over the old one and be done.
| Top |
arcad
Post subject: Re: Replacing AF Labels Posted: Mon Sep 26, 2016 8:37 am |
| Sparks Level |
bbaumer wrote: arcad wrote: Begin by heating one corner of the marking with a blow dryer, heat lamp, hot water or heat gun until hot to the touch. Pick up and lift that area you just heated (use a razor only on glass surfaces). Slowly begin pulling back the decal, at less than a 90 degree angle. Continue applying heat to the area just before the area that is being removed. Once you have removed the marking, check to make sure that all of the adhesive residue has been removed. Remaining residue may be removed by using Isopropyl alcohol (rubbing alcohol). (source: http://arcadvisor.com/faq/apply-vinyl-label-decals) If I did all that I'd never get done with the job. It would take longer to the the bleeping labels on than to do the study. Certainly not worth the effort. Just put the new label over the old one and be done. bbaumer, I was addressing the original question from sam314159
_________________ Michael Furtak, C.E.T. http://arcadvisor.com
| Top |
PaulEngr
Post subject: Re: Replacing AF Labels Posted: Mon Sep 26, 2016 6:25 pm |
| Plasma Level |
bbaumer wrote: If I did all that I'd never get done with the job. It would take longer to the the bleeping labels on than to do the study. Certainly not worth the effort. Just put the new label over the old one and be done. It's really not that slow. The glue softens almost immediately with a heat gun. It peels up pretty quickly. I don't have a good photo to show but I've seen panels with multiple labels stacked not only on top of each other but also multiple VISIBLE labels on the same panel which needless to say makes it extremely confusing as to what the correct values are.
| Top |
wilhendrix
Post subject: Re: Replacing AF Labels Posted: Tue Oct 04, 2016 7:12 am |
With damaged labels I'd go to the effort of removing them using the heat gun method described. For the others, I'd put the new label over the old. Of course, this assumes the new labels are as large as the old.
| Top |
Page 1 of 1
[ 10 posts ] |
