| Author |
Message |
rmgbob
Post subject: Differential Relays Posted: Fri Feb 17, 2017 6:30 am |
I was wondering if anyone can tell me why differential relays are ignored in the arc flash calculations, specifically in the EasyPower software. I'm assuming other software ignore them also. Is it because they are generally used for transformer protection? Does IEEE say that they cannot be considered? I do know the way to have them modeled within the software, I just want to know the reason they are ignored?
| Top |
PaulEngr
Post subject: Re: Differential Relays Posted: Fri Feb 17, 2017 2:44 pm |
| Plasma Level |
Joined: Tue Oct 26, 2010 9:08 am Posts: 2178 Location: North Carolina
rmgbob wrote: I was wondering if anyone can tell me why differential relays are ignored in the arc flash calculations, specifically in the EasyPower software. I'm assuming other software ignore them also. Is it because they are generally used for transformer protection? Does IEEE say that they cannot be considered? I do know the way to have them modeled within the software, I just want to know the reason they are ignored? At least SKM does not "ignore" them. Since they normally are set up with instantaneous tripping they are assumed to trip in 1 cycle and give the minimum time to trip. Same thing with arc flash relays and di/dt relays which work similarly as far as giving "instantaneous" trip speeds (in 1 cycle). Usually the net result is that incident energy is extremely low as a result. That's in the current version of SKM. In the 6.50 and earlier versions it also ignored these types of relays.
| Top |
stevenal
Post subject: Re: Differential Relays Posted: Fri Feb 17, 2017 4:24 pm |
| Top |
matt_engr
Post subject: Re: Differential Relays Posted: Fri Feb 17, 2017 4:58 pm |
As an example, if I wanted to implement bus differential protection in the software, I need to modify the clearing time for the specific bus in my model. The new calculation for incident energy now takes into account the differential protection clearing time.
| Top |
wbd
Post subject: Re: Differential Relays Posted: Mon Feb 20, 2017 6:25 am |
| Plasma Level |
Joined: Wed May 07, 2008 5:00 pm Posts: 881 Location: Rutland, VT
With EasyPower, you can put a user defined time for the bus being faulted. I will take the operate time of the relay, the operate time of any LOR in the circuit and the breaker operate time, add all those together and use that as the time for the bus to be cleared. This is under the Arc Flash Hazard tab > Trip Times for this Bus > drop down box User-defined times
_________________ Barry Donovan, P.E. www.workplacesafetysolutions.com
| Top |
RECS
Post subject: Re: Differential Relays Posted: Mon Feb 20, 2017 7:57 am |
Joined: Sat Apr 04, 2009 9:50 pm Posts: 122 Location: San Antonio, TX
It is a three step process.
| Top |
Robertefuhr
Post subject: Re: Differential Relays Posted: Mon Feb 20, 2017 9:52 am |
| Sparks Level |
Joined: Tue Oct 26, 2010 5:00 pm Posts: 201 Location: Maple Valley, WA.
Select which buses are in the differential relay zone. Click on each bus, Arc Flash Instantaneous Protection Box, type in the Differential Relay Name (ID) (See the attached file.) Click on the in the "Available " box. After you have done this for all buses, run the Arc Flash module/program. Manually type in the tripping time which is the sum of differential relay trip time + lock out relay time + breaker contact parting.
| Attachments: |
_________________ Robert Fuhr, P.E.; P.Eng. PowerStudies
| Top |
DMB5mil
Post subject: Re: Differential Relays Posted: Wed Apr 12, 2017 9:55 am |
As the user above mentions, Easypower has the ability to model Diff Relays, but you have to manually enter in the information. Here is a link to an EP article on the subject: http://feedback.easypower.com/knowledge ... -easypowerAlso, as I'm sure you know, differential relaying only adds protection for the panel you are differentiating around (measuring the in and out fault current). Differential protection will not improve safety of the system downstream of said panel. Good Luck, Brian
| Top |
PaulEngr
Post subject: Re: Differential Relays Posted: Thu Apr 13, 2017 5:01 pm |
| Plasma Level |
| Top |
JBD
Post subject: Re: Differential Relays Posted: Fri Apr 14, 2017 7:08 am |
Joined: Mon Jan 18, 2010 11:35 am Posts: 616 Location: Wisconsin
| Top |
stevenal
Post subject: Re: Differential Relays Posted: Fri Apr 14, 2017 8:49 am |
| Top |
JBD
Post subject: Re: Differential Relays Posted: Fri Apr 14, 2017 10:30 am |
stevenal wrote: Please explain "Virtual Main." A Virtual Main uses CTs mounted on the secondary side of a transformer to trip a physical protective device located on the primary side. One of the primary advantages they offer is add protective functions to equipment that was built without a single main device. Their instantaneous settings do not need to accommodate transformer inrush, therefore they often reduce the AF incident energy below that provided by just having a primary side device.
| Top |
PaulEngr
Post subject: Re: Differential Relays Posted: Fri Apr 14, 2017 5:08 pm |
| Plasma Level |
| Top |
stevenal
Post subject: Re: Differential Relays Posted: Mon Apr 17, 2017 11:30 am |
| Top |
PaulEngr
Post subject: Re: Differential Relays Posted: Mon Apr 17, 2017 1:26 pm |
| Plasma Level |
| Top |
Page 1 of 1
[ 15 posts ] |
