It is currently Mon Nov 23, 2026 10:45 am
 Post subject: Protective Device Bolted Fault & Arcing Fault Current Eqn
PostPosted: Thu Aug 31, 2017 2:18 pm
Iabr=Ia*IBbr/IB;
Iabr: is arcing fault current through each protective device
IBbr: is Bolted Fault Current through each protective device
Ia: is bus arcing fault current
IB: is bus bolted fault current
We can easily compute Ia & IB by IEEE 1584 equations, but I could not find Iabr & IBbr from the above equations. There are two unknown parameters in one equation. Can anyone share a complete equation, if you have please. You may find it in Annex D of CD ROM if you have a copy of IEEE 1584 2002 edition.
