It is currently Mon Aug 03, 2026 1:24 am
 Post subject: Arc Flash SKM overhead Un-insulated Medium Voltage
PostPosted: Tue Jul 17, 2018 1:42 pm
Anybody more familiar with SKM than myself that could help me locate a library, or download a library for overhead cables? I've got some long runs I'm calculating for a medium voltage system arc flash study for an existing system. My overhead wires are run in parallel un-insulated in the air spaced about 2 feet apart. I'm running about 24.9kV in some places and 8.32kV in others. Any cable advice I can plug into skm to model this? I'm also open to other software recommendations if there's something out there more geared towards overhead transmission.
 Post subject: Re: Arc Flash SKM overhead Un-insulated Medium Voltage
PostPosted: Fri Jul 20, 2018 9:49 am
SKM and well as the other software has provisions for overhead wire/cable. There is no "library" because the impedance is affected by the line spacing and distance from the ground. SKM has a very simple method for entering the info but the info must be known.
PostPosted: Mon Jul 30, 2018 5:23 am
Ricky,
Have you had any luck with this? If you need a hand with filling in the information you can probably post a couple of pictures here and we can help you out.
