It is currently Sat Oct 10, 2026 9:21 am
 Post subject: Etap 7.1 Utility Model
PostPosted: Wed May 26, 2010 11:09 am
I have a two pot delta configuration as my utility source, three phase open wye to open delta, 12kv to 120/240. Any suggestions as to how to set up an open delta secondary in Etap? Thanks for any help.
PostPosted: Wed May 26, 2010 5:05 pm
In the transformer data menu there is selection to specify the type of secondary winding configuration. It allows you to select either delta or wye, open, solid, resistance grounding.
