Coordination Studies
On Demand Class | 6 Hours | 28 Modules | By Jim Phillips, P.E.
- 6 PDHs | 0.6 CEUs
- 28 Video Modules
- Many In Class Problems
- Final Quiz – Minimum Passing Score of 70% Required for Continuing Education Credit
- Take the quiz as many times as you need
- Certificate of Completion with PDH/CEU Credit
- Program does NOT expire
- Store this program in your personal library for future reference
- Packed with in class examples and and problems
- WATCH the Video Preview on the left above left
Groups of 4 or more receive discounts of 25% off!
Groups of 10 or more receive discounts beginning at 30% off.
Larger groups? contact us as many other companies have done.
Questions? Call us at 800-874-8883 (US) or email us at [email protected] for details about group/corporate rates.
About the Class
A coordination study, sometimes known as protective device coordination analysis, protection study and similar terms, is an “attempt” to select and set devices to minimize the extent of an outage when a fault or overload occurs. Ideally only the device closest to the fault should operate and clear with the other devices remaining closed. This minimizes the extent of the outage.
Accomplishing selectivity between devices typically requires that each device further upstream and closer to the source be a bit less sensitive and often have some intentional time delay. This approach is good for selectivity but what about protection? Setting devices with more time delay can result in unnecessary damage if the fault is to be cleared by a device that has delay.
Selectivity and protection are two competing objectives. In this class, Jim Phillips takes you step by step though the coordination study process. In addition, in this unique class based on his four decades of experience, he shows you how to manually construct the graphs which has become a lost art in the age of “there’s an app for that”
You will see how to make decisions regarding compromises in selectivity that are often necessary to achieve the best overall coordination. You will also learn about ground fault protection, coordinating current limit fuses, electronic trip circuit breakers, setting protective relays as well as how to protect transformers based on the ANSI C57 thru fault curves. The final case problem illustrates how to address making compromises when perfect coordination is not attainable.
This class was recorded during the week long “Electrical Power System Engineering Class”
Agenda
COORDINATION STUDY REQUIREMENTS
Selective Coordination Basics, Understanding Time Current Curves (TCC), Data Requirements, Device Settings, Graph Scale Selection, Protection vs. Selectivity and Reliability, Compromises in Coordinating Devices in Series
COORDINATION OF MOLDED CASE CIRCUIT BREAKERS
Molded Case Circuit Breaker Time Current Curves, Overload Region of TCC, Instantaneous Region, Fixed vs. Adjustable Instantaneous, Determining the Setting of the Instantaneous, Drawing Time Current Curves. In Class Problem – Drawing Molded Case Circuit Breaker Time Current Curves, Selecting Settings for Optimal Selective Coordination, Evaluating What Happens During Mis-Coordination
COORDINATION OF FUSES
Time Current Curves of Fuses, Current Limiting vs. Non Current Limiting Fuse Curves, Minimum Melting and Total Clearing Curves, Coordinating Two Sets of Current Limiting Fuses with Selectivity Tables, Coordinating I2T Let-Thru Energy. In Class Problems – Coordinating Fuses with Each Other and Coordinating Fuses with Circuit Breakers
SOLID STATE / ELECTRONIC TRIP BREAKERS
Long Time, Short Time, Instantaneous Settings, I2T Settings, Coordination of Electronic Trip Circuit Breakers, Eliminating Instantaneous for Coordination, NEC® Requirements for High Speed Fault Clearing for Reducing the Hazard From an Arc Flash
GROUND FAULT RELAYS
Residually Connected Ground Fault Schemes, Zero Sequence Ground Fault Relaying, Settings, NEC® Requirements for Ground Fault Protection of Services, Feeders and Equipment, Nuisance Tripping, Setting Ground Fault Devices
OVERCURRENT RELAYS
Protective Relay Operation, Amp Tap Setting, Time Dial Operation and Setting, Instantaneous Function, Current Transformers, Necessary Protective Relay Time Margins for Selective Coordination, Setting Selection, Protective Relay Time Current Curves, Curve Shape – Inverse, Very Inverse, Extremely Inverse. In Class Problems – Setting Overcurrent Relays and Drawing Relay Time Current Curves
TRANSFORMER PROTECTION
NEC® Article 450 Requirements, Magnetizing Inrush Current, Using ANSI C57 Thru Fault Curves for Transformer Protection, Adjustments to the Thru Fault Curves Based on Transformer Winding Configurations, Setting Overcurrent Relays for Protecting a Transformer Based on ANSI C57
TIME CURRENT CURVES AT TWO DIFFERENT VOLTAGE LEVELS
Evaluate what happens when coordinating a transformer primary and secondary device at two different voltage levels. See how to adjust the TCCs
CASE PROBLEM
Coordination Study of Small Industrial Plant, Determining Optimal Device Settings and Drawing Time Current Curves for Multiple Devices in Series.
