If the utility short circuit current changes, what could possibly go wrong? It is quite an extensive list. However, I want to focus on how a change with the utility short circuit current and equivalent impedance can affect parallel resonance which is critical in a harmonic study.
I had a client with a power system that was operating with no issues. Then one day, the capacitors began to fail. Why? They had not made any changes.
During the investigation it was discovered the utilities had changed their configuration and were using an alternate distribution line upstream. This changes the equivalent impedance which shifted the parallel resonance to a frequency almost identical to that created by their drives.
Watch this video as I explain how changes to the utility system can make harmonic issues appear out of nowhere. What are the resonance trends when capacitor and utility data changes.
This video is from my live 32 hour Electrical Power System Engineering Class and also the on-demand class: Análisis de factores de potencia y armónicos
| Galleta | Duración | Descripción |
| cookielawinfo-checbox-analytics | 11 meses | Esta cookie está configurada por el complemento GDPR Cookie Consent. La cookie se utiliza para almacenar el consentimiento del usuario para las cookies en la categoría "Analíticas". |
| casilla de verificación funcional de cookielawinfo | 11 meses | La cookie está configurada por el consentimiento de cookies de GDPR para registrar el consentimiento del usuario para las cookies en la categoría "Funcional". |
| cookielawinfo-checkbox-otros | 11 meses | Esta cookie está configurada por el complemento GDPR Cookie Consent. La cookie se utiliza para almacenar el consentimiento del usuario para las cookies en la categoría "Otros". |
| casilla de verificación necesaria para cookielawinfo | 11 meses | Esta cookie está configurada por el complemento GDPR Cookie Consent. Las cookies se utilizan para almacenar el consentimiento del usuario para las cookies en la categoría "Necesarias". |
| casilla de verificación de rendimiento de cookielawinfo | 11 meses | Esta cookie está configurada por el complemento GDPR Cookie Consent. La cookie se utiliza para almacenar el consentimiento del usuario para las cookies en la categoría "Rendimiento". |
| política de cookies vista | 11 meses | La cookie está configurada por el complemento GDPR Cookie Consent y se utiliza para almacenar si el usuario ha dado su consentimiento o no para el uso de cookies. No almacena ningún dato personal. |
