| Author |
Message |
jsoar
Post subject: How to model a Fused circuit breaker in SKM Posted: Tue Aug 13, 2024 8:13 am |
Hello, How do I model a Fused circuit breaker in SKM? The breaker is 800A Cutler-Hammer DSL-206.
| Attachments: |
| Top |
bbaumer
Post subject: Re: How to model a Fused circuit breaker in SKM Posted: Tue Aug 13, 2024 3:19 pm |
| Arc Level |
Looks like you have an Eaton Magnum DS with current limiters. Just put the breaker and current limiting fuses in series with each other. Here is an example but I don't know exactly which breaker you have or what the amp rating is of the limiter so I just somewhat randomly picked them. This is in SKM. Attachment:
_________________ 95% Retired
| Top |
jsoar
Post subject: Re: How to model a Fused circuit breaker in SKM Posted: Tue Aug 13, 2024 6:47 pm |
| Attachments: |
| Top |
bbaumer
Post subject: Re: How to model a Fused circuit breaker in SKM Posted: Tue Aug 13, 2024 11:07 pm |
| Arc Level |
| Top |
bbaumer
Post subject: Re: How to model a Fused circuit breaker in SKM Posted: Tue Aug 13, 2024 11:24 pm |
| Arc Level |
Looks like you probably are correct fuse then breaker if I'm seeing this pic correctly. Attachment:
| Top |
bbaumer
Post subject: Re: How to model a Fused circuit breaker in SKM Posted: Wed Aug 14, 2024 1:32 pm |
| Arc Level |
Bus then limiter then breaker according to some old shops I had. You were correct: Attachment:
| Top |
Page 1 of 1
[ 6 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
