It is currently Sun Oct 04, 2026 1:17 pm
 Post subject: In EasyPower how do you move cables labels?
PostPosted: Fri Mar 02, 2012 11:06 am
Hello all,
I have a real basic question. I can not for the life of me get the information labels for cables to move on my EasyPower one line. Does anyone know how to do this or if it even possible? All of the other name and data labels are really easy to move.
Thanks for any responses
-Allan
PostPosted: Mon Mar 05, 2012 11:17 am
Allan, when you say move, how do you mean that? Are you referring to the cable ID (as in C-25) or the actual wire size itself? I am able to move the cable ID (just like with the over current device ID name) but I cannot move the wire information. The wire info looks like it's attached to the wire itself.The only way I can move the wire ID is by moving the OC device that's attached to the wire. Then the wire information moves. Not sure if this helped at all.
