It is currently Tue Sep 29, 2026 2:46 pm
 Post subject: Relay Settings SKM
PostPosted: Fri Mar 16, 2012 1:07 pm
Hello Everyone!!
I am setting up relay settings for Multilin!!! How would I set-up time dial of relay in SKM?
Thank you in Advance!!
PostPosted: Fri Mar 16, 2012 8:11 pm
Set it to coordinate with upstream and downstream overcurrent protective devices.
PostPosted: Mon Mar 19, 2012 9:53 am
Appreciate if you can put your question more specific.
If you know which model you are using, make sure you have them in your SKM library. Once you find them, try the settings tab in component editor.
Like you see in attachment, you need to give time dial setting for different curves (Norm Inverse, Very Inverse, Extreme inverse, etc.)
Hope this helps
PostPosted: Thu Mar 22, 2012 10:10 am
Thanks for your advice!! Thanks for you help nknfive!! It was wired to see the curve and Time dial was actually in Settings 1. !!!
I am use to of ETAP so it was quite wired to see the way things are presented in SKM!!!
