It is currently Sun Nov 22, 2026 6:33 am
 Post subject: Engineering oversite
PostPosted: Mon Jun 04, 2012 11:57 am
Is there any requirements that an arc flash study must be performed by an engineer? If not is there any other qualifications required?
PostPosted: Mon Jun 04, 2012 3:38 pm
There is no national requirement relating to qualifications to perform studies.
Most states would probably include arc flash studies under their 'general engineering laws' (i.e. Professional Engineering licensing rules) due to the safety issue associated with the results.
PostPosted: Tue Jun 12, 2012 8:52 am
There is no real requirement in any ofthe standards, BUT in any area that does require electrical engineering work to be performed by a Lic. Engineer, it is likely to be considered "engineering Work" and hence required to be performed either "under the supervision of" or directly by a PE.
[The situation can get a little sticky when one performs a study for a facility in State A, for a Client in State B, while physically being in state C. Technically one might have to be a PE in all 3 to be completly covered.]
PostPosted: Tue Jun 12, 2012 11:09 am
The governing engineering laws are always those of the location in which the facility exists. My company regularly (i.e. daily) performs studies based on the scenario you described, the only seal affixed to the report is that of the facilities locale.
