It is currently Tue Sep 29, 2026 11:07 am
 Post subject: Gloves
PostPosted: Fri Jan 16, 2009 2:25 pm
Does anyone know if you can use line gloves with leather rated for ANSI/ASTM Class 00 D120 type 1 , 500V AC MAX in a level 2 AF area or do you need different gloves? Reason I ask is because I cant find any level 2 gloves on the web only 3 & 4 so do the want you to level up, or are the ones I have ok? Thanks
PostPosted: Fri Jan 16, 2009 7:04 pm
The rubber gloves with the leather protectors is sufficient hand protection.
PostPosted: Sat Feb 28, 2009 7:45 pm
FYI, Hugh Hotgland was hired by one of the rubber insulating glove manufacturers and the rubber insulating gloves (black color) with the leather protector can provide significant arc flash protection in the 50-90 cal/cm2 range.
Regards;
Terry Becker, P.Eng.
http://www.esps.ca
