It is currently Fri Oct 16, 2026 5:09 am
Do you perform arc flash studies and what voltage?
Yes - up to 15 kV 41%  41%  [ 17 ]
Yes - above 15 kV 2%  2%  [ 1 ]
Yes - Both voltage ranges 51%  51%  [ 21 ]
No - I don't perform studies 5%  5%  [ 2 ]
Total votes : 41
 Post subject: Do you perform arc flash studies? What Voltage?
PostPosted: Sun May 01, 2016 5:29 pm
This week's question is pretty simple:
Yes - up to 15 kV
Yes - above 15 kV
 Post subject: Re: Do you perform arc flash studies? What Voltage?
PostPosted: Mon May 02, 2016 4:45 am
Our system is 13.8kV and below.
The utility transformers (110kV) are included in the SKM model.
