It is currently Wed Oct 07, 2026 5:10 am
Do you use/specify default enclosure sizes or actual enclosure sizes for arc flash studies?
Default sizes 52%  52%  [ 22 ]
Actual sizes 17%  17%  [ 7 ]
A mix 29%  29%  [ 12 ]
Not sure 0%  0%  [ 0 ]
Not involved with studies 2%  2%  [ 1 ]
Total votes : 42
 Post subject: Arc Flash – Modeling Enclosure Size
PostPosted: Sun Jun 27, 2021 12:57 pm
As many know by now, the 2018 Edition of IEEE 1584 provides a method to adjust the incident energy based on the size of the enclosure opening.
Table 8 – Classes of equipment and typical bus gaps contains enclosure sizes for different voltages and classes of equipment.
Most software defaults to these values in the absence of user specified sizes.
Here is this week’s question:
Default sizes
Actual sizes
A mix
Not sure
