| Author |
Message |
Tesla13
Post subject: Grid short circuit data Posted: Mon May 29, 2023 11:56 am |
Hi all,
I would like to have your view regarding external grid short circuit scenarios in Arc Flash calculations. I have some doubts about how this issue should be addressed.
What should I do if there is no info about the available short circuit power in the grid?
As far as I understand, considering only hypothetical maximum and minimum short circuit scenarios for calculation I may not be achieving the “Worst Case” incident energy scenario. The reason is that there may be some intermediate Scc scenarios in which the combination of FCT + Icc may lead to a higher Incident Energy. So the correct approach may be doing a sweep with different values. There is also some scientific literature with conclusions pointing in the same direction.
Similar happens when the utility gives you the data: what about short circuit intermediate scenarios?
How do you see it?
Thanks for your support.
Regards,
| Top |
Tesla13
Post subject: Re: Grid short circuit data Posted: Fri Jun 30, 2023 12:56 am |
| Top |
mpparent
Post subject: Re: Grid short circuit data Posted: Fri Jun 30, 2023 6:50 am |
I think Jim has an article somewhere about this topic.
Mike
| Top |
Page 1 of 1
[ 3 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
