It is currently Thu Apr 30, 2026 3:21 am
 Post subject: SKM ANSI vs Comprehensive for Short Circuit
PostPosted: Mon Aug 26, 2024 2:12 pm
Just curious which you all prefer. It seems that the comprehensive method might be more accurate but maybe smaller, less complicated systems don't need to run Comprehensive? Thanks =)
 Post subject: Re: SKM ANSI vs Comprehensive for Short Circuit
PostPosted: Mon Aug 26, 2024 2:26 pm
What I've noticed is the results are exactly the same except for motor contribution.
SKM jockey for hire
PE in 17 states
PostPosted: Thu Aug 29, 2024 6:44 am
Use ANSI since CB ratings are determined from that standard.
Mike
