It is currently Thu Oct 29, 2026 11:18 pm
 Post subject: Repair Kit
PostPosted: Mon Sep 20, 2010 8:11 am
Has anyone recieved or heard of an FR repair kit? One that might include patches that you can heat seal?
PostPosted: Mon Sep 20, 2010 9:11 am
Most PPE providers will give you a repair kit, keep in mind the manufacture will have specific repair guidelines and all materials used have to be FR, thread and patch (same ATPV rating for the patch).
PostPosted: Tue Sep 21, 2010 11:17 am
Thank you Zog
PostPosted: Tue Sep 28, 2010 1:48 pm
Workrite has patch material that is of the heat transfer type. Below are the basic requirements.
General:
• The patching fabric must be the same as the garment fabric.
• For minor tears and thin spots apply per application instructions below.
• For holes; no adhesive is to be exposed to the skin
• Patches should not exceed 2� x 4�.
Application:
• Use a heat press
• Upper plate temperature 400° F
• Lower plate temperature 350° F
• Press load 80 lbs.
• Dwell time 10 seconds
