It is currently Tue Aug 11, 2026 4:16 pm
 Post subject: Have Your Articles Published On Arc Flash Forum
PostPosted: Fri Feb 03, 2012 1:11 pm
Authors / Contributors Wanted! - Get noticed!
Be one of our forum contributors and get noticed by thousands of forum visitors each month. Post your arc flash and electrical safety articles at our [url='http://www.arcflashforum.com/forums/34/']Library/Articles Section[/url]. Any full forum member in good standing can contribute to the articles section.
The articles posted in our [url='http://www.arcflashforum.com/forums/34/']Library/Articles Section[/url] will be reviewed by a Moderator before they are published. So after submission it may take a few hours before your Article appears.
Format
The submission format is same as creating any New thread topic anywhere else at the forum. Just go to the [url='http://www.arcflashforum.com/forums/34/']Articles Section[/url] and click on the black button which says "Post New Thread" .
It works best if your content can be uploaded through our editor, which is shown once you click on the "Post New Thread" button. This works better than simply linking to a PDF or outside link.
We will not accept submissions which just link to outside content. We will however accept PDF's, only if it is not possible for you to post the actual article content using the text editor for some reason.
We however strongly recommend that if you have your article in a PDF then copy the PDF text and paste it in our editor and format it instead of merely uploading PDFs.
Copyright/Permission
By submitting an article, you agree that you hold the copyright of have permission from the copyright holder to post the article. Any copyright violations will be deleted. If you see content posted that you believe is in violation of copyright laws, please contact the administrator immediately.
