Why NFPA 70E Labels Aren’t Always Consistent
Pregunta:
Some arc-flash labels list the arc-flash boundary in inches, others in millimeters or meters, and some even show odd values like 3.4 feet. On top of that, IEEE 1584 uses joules per square centimeter (J/cm²), but PPE ratings are in calories per square centimeter (cal/cm²). Why is there so much inconsistency on NFPA 70E arc flash / equipment labels?
Respuesta:
It looks messy, but there’s a logical reason behind it. The short version is this: IEEE 1584 is based on metric units, and the end user prefers imperial units (inches etc.) for NFPA 70E labels. However, the units used on arc flash labels still seem to vary widely
IEEE 1584 Is Metric by Requirement
IEEE as well as many other standards requires the use of the metric system in its equations. As a result, IEEE 1584:
  • Arc-flash boundary distances are calculated in millimeters
  • Incident energy is calculated in joules per square centimeter (J/cm²)
This isn’t optional. IEEE standards are written to be internationally applicable, and the metric system is required for consistency. It should be noted that IEEE 1584 is a global standard and some countries or regions do prefer metric units.
So when an arc-flash study is performed, the raw calculation results coming out of IEEE 1584 are always metric — even if you never see those units on the final report or label.
Why Labels Show Inches, Feet, or Decimals
NFPA 70E does no mandate a specific unit system for arc-flash labels. What NFPA 70E 130.5(H) does require is that electrical equipment be labeled with meaningful arc-flash information so workers can recognize the hazard and take appropriate protective measures.
To meet that requirement, arc-flash software typically converts:
  • Millimeters into inches, feet, or meters
  • Based on user preference, company standards, or regional practice
That’s why you may see:
  • 42 inches on one NFPA 70E label
  • 1.1 meters on another
  • 3.5 feet on a third
The math is correct — it just wasn’t rounded to a “nice” number after conversion. From an NFPA 70E standpoint, that’s acceptable as long as the information is accurate and clearly communicated.
Incident Energy: J/cm² vs cal/cm²
The same issue shows up with incident energy.
IEEE 1584 is used to calculate incident energy in J/cm², where:
  • One joule equals one watt-second
However, PPE Ratings defined by standards such as ASTM and IEC and referenced in NFPA 70E are based on cal/cm², and arc-rated clothing and face shields are tested and labeled in those units.
Because NFPA 70E requires PPE selection based on incident energy exposure, arc-flash software converts:
  • J/cm² into cal/cm²
  • So the value on the NFPA 70E label matches PPE ratings and hazard categories
Again, the inconsistency isn’t an error — it’s a necessary translation between calculation standards and safety requirements.
What NFPA 70E Actually Cares About
NFPA 70E 130.5(H) doesn’t care whether a distance is shown in inches, feet, or meters. It cares that:
  • El arc-flash boundary is clearly identified
  • The incident energy or PPE information is accurate
  • The label supports the arc-flash risk assessment
As long as the label addresses the requirements of NFPA 70E 130.5(H) and aligns with the arc-flash study, the units are technically a secondary concern.
The Real Problem: Confusion, Not Conversion
Where this becomes an issue is worker interpretation. A label that mixes unfamiliar units or odd decimal values can:
  • Slow down decision-making
  • Increase the chance of misreading a boundary
  • Reduce confidence in the NFPA 70E labeling program
That’s why many companies standardize:
  • One distance unit system
  • One rounding convention
  • One label format across the facility
This isn’t required by NFPA 70E — but it’s often a very good idea.
Bottom Line
The unit differences on arc-flash labels exist because:
  • IEEE 1584 requires metric units
  • NFPA 70E requires usable safety information
  • Software bridges the gap by converting units for labels
As long as the label meets NFPA 70E 130.5(H) requirements and accurately reflects the arc-flash study, the units are technically correct — even if they don’t always look consistent.
Jim Phillips, P.E. presenting beside a large conference screen
Jim Phillips, P.E. presenting at an Arc Flash Electrical Safety event in Brisbane
How 45 Years of Experience Built Jim’s NFPA 70E and IEEE 1584 Expertise
Jim Phillips is an internationally recognized authority in electrical power systems, arc-flash analysis, and electrical safety, with more than four decades of professional experience. He has delivered over 3,000 training programs worldwide, educating tens of thousands of people from all seven continents, (Yes, Antarctica is included!) Known for his clear, engaging presentation style, Jim is widely regarded as one of the industry’s leading trainers and public speakers.
His professional background spans transmission system planning; industrial, commercial, and utility power system design and analysis; co-generation plant design; and forensic engineering investigations. He is also frequently engaged as an expert witness in matters involving electrical power systems and arc-flash hazards
  • Founder and President Brainfiller.com
  • Fundador de ArcFlashForum.com
  • Director asociado | Electrical Safety UK, Ltd. – Rotherham, Reino Unido
  • Contributing Editor | Award Winning NECA Magazine Electrical Contractor
Arc Flash and Standards Committees Leadership
For decades, Jim Phillips has been actively involved with U.S. and international standards development.  This includes:
  • Vice Chair: IEEE 1584 – IEEE Guide for Performing Arc-Flash Hazard Calculations
  • International Chair Emeritus: IEC TC78 – International Live Working and Arc Flash Standards
  • Chair: IEEE PCIC Electrical Safety Subcommittee
  • Miembro del Comité Técnico: Norma NFPA 70E para la seguridad eléctrica en el lugar de trabajo
  • Technical Committee Member: National Electrical Code – CMP 4
  • Comité Directivo: Proyecto de Investigación Colaborativa sobre Arco Eléctrico IEEE/NFPA
Arc Flash investigation
Fukushima after Arc Flash
NFPA 70E Training Courses Available Through Brainfiller
Brainfiller offers several courses designed and taught by Jim, all targeted to engineers, electricians, and safety professionals.
NFPA 70E Qualified Worker Training (8 hours)
Covers risk assessment, PPE, LOTO, establishing an electrically safe work condition, and auditing requirements.
How to Perform an Arc-Flash Study | IEEE 1584 (16 hours)
Modeling, arcing current, incident energy, arc-flash boundaries, and system-level mitigation.
Fundamentals of Electrical Safety (2 hours)
Shock hazards, arc-flash basics, and the building blocks behind NFPA 70E.
DC Electrical Safety Fundamentals (2 hours)
Key safety practices for data centers and DC systems.
All training is available live, on-site, or on-demand, and includes completion certificates with CEU/PDH documentation.
Elevate Your Electrical Safety Program
Train with Jim Phillips through Brainfiller.
Empower your team, strengthen compliance, and protect lives with industry-leading NFPA 70E and IEEE 1584 arc-flash training.
