IAEI News – March, 1930 – Vol. II No. 2
Reprinted with permission from “IAEI News” by the International Association of Electrical Inspectors (IAEI). Copyright © 1929 to 2020 by the International Association of Electrical Inspectors. Current articles may be found online at https://www.iaeimagazine.org.
The March 1930 issue contains stories such as:
Adequacy Requirements for Branch Circuit Wiring (page 10) This article points out that the table with a minimum required watts per unit area of the NEC does not of itself assure an adequate wiring layout. This appears to be the predecessor of NEC Table 220.12
Ohio Supreme Court Ruling about Liability (page 25) This 1929 ruling clarifies the right to recover damages from the property owner if they are negligent of fire hazards and his tenants suffer fire losses as a result.
Electrical Accidents Reports (page 29) Fatality from wires that were not removed, Handyman falls and grabs live terminals (all while using a lantern for illumination) Long before NFPA 70E, this article provides many more unfortunate stories.
Steel Underfloor Ducts (page 26) Underfloor ducts as a standardized manufactured produce was almost unheard of until recent years. This article references only one installation prior to 1920.
Plus local section reports and much more!
