Brainfiller Videos
Harmonic Analysis – What if Utility Data Changes?
Harmonic Analysis – What if Utility Data Changes? If the utility short circuit current changes, what could possibly go wrong? It is quite an extensive list. However, I want to
WATCH NOW
Harmonic Analysis Resonance Trends
Harmonic Analysis – Resonance Trends Parallel resonance in electrical power systems occurs when the system inductance is in parallel with power factor correction capacitors at a given location. If the
WATCH NOW
2024 NFPA 70E Which Edition of a Standard Do You Use if No Date is Given?
2024 NFPA 70E Which Edition of a Standard Do You Use if No Date is Given? NFPA 70E references other codes and standards such as other NFPA standards as well
WATCH NOW
2024 NFPA 70E Evidence of Impending Failure – Water Damage
2024 NFPA 70E Evidence of Impending Failure – Water Damage Evidence of Impending Failure – Water Damage 2024 NFPA 70E 110.2(B) Exception No. 1 lists seven conditions that must be
WATCH NOW
2024 NFPA 70E Global Changes
Each edition of NFPA 70E contains changes that impact or are seen throughout the entire standard. Known as “Global Changes” the 2024 Edition has three major global changes that include:
WATCH NOW
Normal Operating Condition: Equipment Rated for Available Fault Current
The 2024 Edition of NFPA 70E added “The equipment is rated for the available fault current” to the list of conditions for when a normal operating condition exists in Section
WATCH NOW
2024 NFPA 70E – Test Absence of Voltage at EACH POINT OF WORK
Five simple words “at each point of work” were added to step 7 of the Process for Establishing and Verifying an Electrically Safe Work Condition. Step 7 is testing absence
WATCH NOW
No Short Circuit Data Available? Try an Iterative Approach.
No Short Circuit Data Available? Try an Iterative Approach. The available short circuit data (fault current) from the electric utility or other source is a very important variable when conducting
WATCH NOW
Why Does Utility Fault Current Change
Why Does Electric Utility Fault Current Change The available fault current from an electric utility can change over time creating unique challenges for power system studies such as short circuit
WATCH NOW
Resetting a Tripped Circuit Breaker – Normal Operation?
QUESTION: Would opening or closing a circuit breaker be considered normal operation?  What about resetting a tripped circuit breaker?  This short explanation is from the Q&A Session during my 2024
WATCH NOW
2024 NFPA 70E – Major Changes
“NFPA 70E requires retraining at intervals not to exceed 3 years“ Retraining in safety-related work practices and applicable changes to NFPA 70E shall be performed at intervals not to exceed
WATCH NOW
Coordination Studies Preview | On Demand Training
This video provides a short overview of the 6 PDH/ 0.6 CEU On-Demand Training Program: Coordination Studies by Jim Phillips, P.E. A coordination study, sometimes known as protective device coordination
WATCH NOW
Coordination Studies | Determining Device Priority
Achieving perfect coordination may seem as elusive as spotting a unicorn. In order to obtain perfect coordination, overcurrent devices are selected and set so that only the device nearest a
WATCH NOW
2021 NFPA 70E – Major Changes
NFPA 70E states that retraining in safety-related work practices and applicable changes in this standard shall be performed at intervals not to exceed 3 years. This time frame is so
WATCH NOW
Arc Flash Studies and Electric Utility Company Short Circuit Data
What do you do if the short circuit data is unavailable from the electric utility company? Can you use an “infinite source” calculation? Many say an infinite source is not
WATCH NOW
Arc Flash Plasma – Modify the Arc Rating or Modify the Incident Energy Calculations?
Why Horizontal Electrode Configuration? Although not the most common electrode configuration that is used when performing an arc flash study, using the Horizontal Conductors/Electrodes inside a metal box/enclosure (HCB) produces
WATCH NOW
Group Discounts
Group Discounts: Need to train your staff? Take advantage of our group training discounts.
4 or more: 25% discount | 10 or more: 30% discount | Larger Groups may qualify for Larger Discounts!
Call us for a proposal.
