Arc-Flash Boundary and NFPA 70E — Is It a “Safe” Place to Stand?
Question: Arc Flash Boundary – Safe?
Since NFPA 70E does not require arc-flash PPE outside of the arc-flash boundary, does that mean it’s a safe place to stand?
The Short Answer:
I would not stand there – without some protection! – Really? Yes, but I have the advantage of seeing many staged arc flash events in the lab so I know what it can do.
What NFPA 70E Actually Says About the Arc-Flash Boundary
Let’s start with the basics.
NFPA 70E requires that an arc-flash boundary (AFB) be determined and as part of an arc-flash risk assessment (see NFPA 70E Article 130.5).
However, nowhere in NFPA 70E—and nowhere in IEEE 1584—does it say that:
  • The arc-flash boundary defines a safe area
  • Standing just outside the boundary is hazard-free
That’s a common (and potentially dangerous) misconception.
Cover of the 2024 NFPA 70E electrical safety standard
The Technical Definition of the Arc-Flash Boundary
The arc-flash boundary is defined as:
The distance from a prospective arc-flash source at which the incident energy equals 1.2 cal/cm².
That value—1.2 cal/cm²—is widely considered to be the approximate threshold for the onset of a second-degree burn on unprotected skin.
And that’s it.
The arc-flash boundary:
  • Is not a safety zone
  • Is not a comfort line
  • Is not a guarantee of zero injury
It’s simply a calculated distance tied to a thermal injury threshold.
Why “Below 1.2 cal/cm²” Does NOT Mean Safe
Even if the incident energy is below 1.2 cal/cm², several serious hazards still exist:
  • Flying molten metal and shrapnel
  • Blinding ultraviolet and visible light
  • Extreme sound pressure (arc blast)
  • Pressure waves
  • Thermal exposure below burn threshold
NFPA 70E focuses heavily on thermal injury, but arc-flash events are far more complex than heat alone.
Standing just outside the arc-flash boundary does not protect you from:
  • Temporary or permanent vision damage
  • Hearing damage
  • Impact injuries
  • Secondary burns
  • Being knocked off balance
None of those are addressed by the 1.2 cal/cm² line in the sand.
The Human Factors Problem
One of the biggest issues I see in the field is people treating the arc-flash boundary like a magic force field from a science fiction movie.
It’s not!
Arc-flash calculations—whether performed using IEEE 1584 or another method—are still models, not guarantees. Small changes such as:
  • Working distance
  • Body position
  • Arc behavior
  • Protective device clearing time
can significantly change the actual exposure during an event.
Splitting hairs over inches or feet is a losing strategy.
The intent of NFPA 70E is risk reduction and preferably – elimination, not mathematical loopholes.
Unless you are properly trained, qualified, part of the work team and properly protected, then you have no business being in the area—boundary or not.
Practical Guidance (From the Real World)
Here’s the rule of thumb I’ve always used and taught:
If you’re not wearing properly rated arc-flash PPE, leave the area.
Don’t argue about whether you’re:
  • 6 inches outside the arc-flash boundary
  • 1 foot outside
  • 3 feet outside
If an arc flash occurs, you won’t care what the calculation said.
Key Takeaways (NFPA 70E Focused)
  • NFPA 70E requires determination of the arc-flash boundary
  • The arc-flash boundary is based on 1.2 cal/cm², not “safety”
  • Outside the boundary does not mean hazard-free
  • Arc-flash hazards include more than thermal injury
  • Calculated boundaries are not precise protection zones
Final Thought
The arc-flash boundary is a planning tool, not a permission slip.
Don’t stand there.
Don’t test the math.
Don’t assume “outside” means “safe.”
💡 Did you know? Many NFPA 70E trainers learn the material by attending Jim’s classes—while Jim is involved directly with the standards they teach.
Jim Phillips, P.E. presenting beside a large conference screen
Jim Phillips, P.E. presenting at an Arc Flash Electrical Safety event in Brisbane
How 45 years of Experience Built Jim’s NFPA 70E Expertise
Jim’s background spans:
  • Fault studies and power-system analysis
  • Electrical system design and coordination
  • Forensic and root-cause investigations
  • Arc-flash laboratory research
  • Standards committee involvement for 20+ years
This progression gives Jim a rare, 360-degree view of electrical hazards—from theoretical models to real-world failures. His training incorporates both the engineering and the practical side of electrical safety.
Arc Flash and IEEE 1584 Leadership
Jim has played a major role in shaping the methodology behind modern arc-flash hazard calculations—the backbone of NFPA 70E’s incident energy analysis and PPE selection.
His instruction includes:
  • Modeling techniques
  • Arcing current calculations
  • Incident energy evaluations
  • Arc-flash boundary determinations
  • Real-world mitigation strategies
Arc Flash investigation
NFPA 70E Training Courses Available Through Brainfiller
Brainfiller offers several courses designed and taught by Jim, all targeted to engineers, electricians, and safety professionals.
NFPA 70E Qualified Worker Training (8 hours)
Covers risk assessment, PPE, LOTO, establishing an electrically safe work condition, and auditing requirements.
How to Perform an Arc-Flash Study | IEEE 1584 (16 hours)
Modeling, arcing current, incident energy, arc-flash boundaries, and system-level mitigation.
Fundamentals of Electrical Safety (2 hours)
Shock hazards, arc-flash basics, and the building blocks behind NFPA 70E.
DC Electrical Safety Fundamentals (2 hours)
Key safety practices for data centers and DC systems.
All training is available live, on-site, or on-demand, and includes completion certificates with CEU/PDH documentation.
Elevate Your Electrical Safety Program
Train with Jim Phillips through Brainfiller.
Empower your team, strengthen compliance, and protect lives with industry-leading NFPA 70E and arc-flash training.
