Hello What is the optimal X factor for disconnect switches. I assumed it is 2 because that’s the default value that ETAP gives you. Am I correct for assuming this? Furthermore, It falls under the low voltage category (0.208-1), so it can be the value for MCC’s and panels which is 1.473. Which value is optimal for Arc Flash calculations? Thanks READ MORE
