Technical Articles
Electrical Safety Training and Culture
Close-up of damaged electrical circuit breaker components
NFPA 70E 110.3 (J) Incident Investigations
NFPA 70E 110.3(J) Incident Investigations Electrical power systems, like all complex systems, are prone to failures. These failures can arise from a wide range of causes, including improper work procedures, faulty or inadequately maintained equipment, or human error, among others.
Read More »
Arc flash warning label showing incident energy information
Date on the Arc Flash (Equipment) Label?
Date on the Arc Flash Label? A common question that I receive during both my NFPA 70E and Arc Flash/IEEE 1584 classes: Is the date required to be the arc flash (equipment) label? Two standards can provide insight into the…
Read More »
Illustration of a person considering an electrical safety question
Arc Flash Studies – Confused?
Arc Flash Studies – Confused? It has been over 20 years since IEEE 1584, IEEE Guide for Performing Arc-Flash Hazard Calculations turns was first introduced to the world on September 23, 2002. All these years later there can still be…
Read More »
2024 NFPA 70E changes training by Jim Phillips, P.E.
2024 NFPA 70E: Major Changes
Jim Phillips, P.E. 2024 NFPA 70E Changes and Refresher Training Register for Jim Phillips’ 8 Hour 2024 NFPA 70E Changes and Refresher Training! February 13 – 14, 2024 April 24 – 25, 2024 July 10 – 11, 2024 2024 NFPA…
Read More »
2024 NFPA 70E Update Jim Phillips, P.E. The 2024 Edition of NFPA 70E: Standard for Electrical Safety in the Workplace is scheduled to be published later this year. First released in 1979, this will mark the thirteenth edition. While some…
Read More »
