Technical Articles
Emerging Electrical Safety Technologies and Trends
The 2022 Edition of IEEE 1584.1 was just published
Over Two Decades of IEEE 1584 Standards
No, the title doesn’t have a typo — “Standards” is plural for a reason. Over 20 years ago, in 2002, the original IEEE 1584 standard was released and changed the game for arc flash safety around the world. Since then,…
Read More »
Continuous thermal monitoring
NFPA 70E 205.4: The Power of Noncontact Diagnostics
NFPA 70E 205.4 and Noncontact Diagnostics If you’re in the electrical world, you’ve probably seen how fast technology is changing the way we maintain equipment. The 2024 edition of NFPA 70E is no exception—it reinforces the importance of keeping electrical…
Read More »
Close-up of damaged electrical circuit breaker components
NFPA 70E 110.3 (J) Incident Investigations
NFPA 70E 110.3(J) Incident Investigations Electrical power systems, like all complex systems, are prone to failures. These failures can arise from a wide range of causes, including improper work procedures, faulty or inadequately maintained equipment, or human error, among others.
Read More »
Arc flash warning label showing incident energy information
Date on the Arc Flash (Equipment) Label?
Date on the Arc Flash Label? A common question that I receive during both my NFPA 70E and Arc Flash/IEEE 1584 classes: Is the date required to be the arc flash (equipment) label? Two standards can provide insight into the…
Read More »
Illustration of a person considering an electrical safety question
Arc Flash Studies – Confused?
Arc Flash Studies – Confused? It has been over 20 years since IEEE 1584, IEEE Guide for Performing Arc-Flash Hazard Calculations turns was first introduced to the world on September 23, 2002. All these years later there can still be…
Read More »
