2022 IEEE 1584.1 Just Published!
IEEE ConferenceI’m happy to announce the latest Edition of IEEE 1584.1 “IEEE Guide for the Specification of Scope and Deliverable Requirements for an Arc-Flash Hazard Calculation Study in Accordance with IEEE Std 1584” was just published.  The working group informally refers to this standard as “dot one”
The first edition of IEEE 1584.1 was published in 2013 as a document to assist in specifying arc flash studies based on the original 2002 Edition of IEEE 1584.  This latest edition has been updated to reflect the 2018 Edition of IEEE 1584.
Scope
This standard provides guidance for the specification and performance of an arc-flash hazard analysis, in accordance with the process defined in IEEE Std 1584, IEEE Guide for Performing Arc-Flash Hazard Calculations. It provides the minimum scope and deliverables for an arc-flash study.
Purpose
The purpose of this standard is to enable stakeholders to understand the minimum scope of work and deliverables required for an arc-flash study. Stakeholders are responsible for personnel in facilities and installations with electrical energy as a potential hazard to employees and other personnel. Stakeholders include but are not limited to employers, owners, operators, and contractors as well as those who are responsible for the specification or the performance of a study.
Abstract
Revision Standard – Active. Guidance for the specification and performance of an arc-flash hazard calculation study, in accordance with the process defined in IEEE Std 1584, is provided in this document. The minimum recommended requirements to enable the owner to specify an arc-flash hazard calculation study, including scope of work and associated deliverables, is outlined.
Obtain Your Copy of 2022 IEEE 1584.1!
This new standard can be obtained at: 2022 IEEE 1584.1
Learn How to Perform Arc Flash Studies with IEEE 1584
Jim Phillips, P.E. teaches you how to perform arc flash studies using the 2018 Edition of IEEE 1584.  This class is loaded with in class problems including calculations of the arcing fault current, incident energy and arc flash boundaries.
The next live streaming class begins August 8, 2022
