Technical Articles
Short Circuit Analysis and Fault Current Calculations
The 2022 Edition of IEEE 1584.1 was just published
Over Two Decades of IEEE 1584 Standards
No, the title doesn’t have a typo — “Standards” is plural for a reason. Over 20 years ago, in 2002, the original IEEE 1584 standard was released and changed the game for arc flash safety around the world. Since then,…
Read More »
Illustration of a person considering an electrical safety question
Arc Flash Studies – Confused?
Arc Flash Studies – Confused? It has been over 20 years since IEEE 1584, IEEE Guide for Performing Arc-Flash Hazard Calculations turns was first introduced to the world on September 23, 2002. All these years later there can still be…
Read More »
2024 NFPA 70E changes training by Jim Phillips, P.E.
2024 NFPA 70E: Major Changes
Jim Phillips, P.E. 2024 NFPA 70E Changes and Refresher Training Register for Jim Phillips’ 8 Hour 2024 NFPA 70E Changes and Refresher Training! February 13 – 14, 2024 April 24 – 25, 2024 July 10 – 11, 2024 2024 NFPA…
Read More »
2024 NFPA 70E Update Jim Phillips, P.E. The 2024 Edition of NFPA 70E: Standard for Electrical Safety in the Workplace is scheduled to be published later this year. First released in 1979, this will mark the thirteenth edition. While some…
Read More »
2022 IEEE 1584.1 Just Published!
2022 IEEE 1584.1 Just Published!: I’m happy to announce the latest Edition of IEEE 1584.1 “IEEE Guide for the Specification of Scope and Deliverable Requirements for an Arc-Flash Hazard Calculation Study in Accordance with IEEE Std 1584” was just published. The working group informally refers…
Read More »
Figure 1 One Line scaled
How to Perform an Arc Flash Study – Part 3
Arc Duration
Arc Duration: Time is everything when an arc flash occurs. The longer the duration, the greater the incident energy exposure – which is directly proportional to the duration. The 2018 Edition of IEEE 1584 defines the arc duration , also referred to…
Read More »
Grounding and Power Quality
How to Perform an Arc Flash Study – Part 2
Arcing Fault Current
Arcing Fault Current: Arcing Fault Current – Effect of Gap, Voltage and Electrode Configuration An arc flash occurs when short circuit current jumps across an air gap between energized conductors. The event is normally the result of initial (and inadvertent) contact between energized…
Read More »
