Technical Articles
Electrical Power System Design and Analysis
Neutral Grounding Resistor
Impedance Grounding and Arc Flash
A short circuit happens when energized conductors accidentally make contact with each other and/or to ground. When that connection forms, the load and its impedance is bypassed resulting usually resulting in a very high magnitude of current. There are several fault types—three-phase, phase-to-phase, and line-to-ground, but the line-to-ground fault is by far the most common. You’ll often see numbers in the 70–80% of all faults falling into this category. Some say this number is even higher. Why so many line-to-ground
Read More »
Close-up of damaged electrical circuit breaker components
NFPA 70E 110.3 (J) Incident Investigations
NFPA 70E 110.3(J) Incident Investigations Electrical power systems, like all complex systems, are prone to failures. These failures can arise from a wide range of causes, including improper work procedures, faulty or inadequately maintained equipment, or human error, among others.
Read More »
Jim Phillips in his PPE
2021 NFPA 70E – Major Changes
Jim Phillips, P.E. Every three years I have the privilege of writing the NFPA 70E Changes article for National Electrical Contractor Association’s magazine: Electrical Contractor . The NFPA 70E 2021 edition of this standard will be available September 4, 2020…
Read More »
