Technical Articles
NFPA 70E
When Horizontal Bus is NOT HCB
Question:I have a switchboard with horizontal bus. Should I use the HCB model? Short answer:Not necessarily. Wait! What? Horizontal might not be horizontal? NFPA 70E requires performing an arc flash risk assessment which usually means using IEEE 1584 equations via software to conduct an arc flash study. This requires the selection of what is known as the equipment electrode configuration. One of the most misunderstood configurations is HCB. Let’s clear up a common misunderstanding. HCB stands for Horizontal Conductors in
Read More »
Arcing Fault Current, NFPA 70E and IEEE 1584
IEEE 1584 defines arcing fault current as the reduced current that flows during an arc flash event, differing significantly from bolted fault current. Understanding this distinction is critical for accurate incident energy calculations, arc flash studies, and NFPA 70E compliance.
Read More »
IEEE 1584.2 Standard
NEW! IEEE 1584.2 was Recently Published
IEEE 1584.2 was recently published! The full title is: IEEE Guide and Checklists for Data Collection for Performing an Arc-Flash Hazard Calculation Study in Accordance with IEEE Std 1584™ and IEEE Std 1584.1™ for Systems Operating at Three-Phase 50/60 Hz AC 1000 V and Below This newest addition to the IEEE 1584 family complements the existing standards: IEEE 1584 – 2018: IEEE Guide for Performing Arc-Flash Hazard Calculations IEEE 1584.1 – 2022: IEEE Guide for the Specification of Scope and
Read More »
Why Jim Phillips Is a Trusted NFPA 70E Expert
Electrical safety isn’t theory—it’s protection for people, equipment, and uptime. For more than 40 years, Jim Phillips has helped engineers, electricians, and safety professionals turn the NFPA 70E Standard for Electrical Safety in the Workplace into practical, actionable safeguards that reduce incidents and strengthen compliance. At Brainfiller, Jim leads some of the industry’s most trusted NFPA 70E training programs, known for converting complex standards into proven, field-ready procedures. What Is NFPA 70E and Why It Matters Developed by the National
Read More »
